dear doc dodge, on the way home from stockton in one of our glorius monsoons today my wipers decided to give up the ghost, the early symptoms of failure were as follows,when trying to turn off wipers they would not return to the correct park position then they ceased to function altogether, when i got home i took off the pivot and the motor seems to rotate ok,lubed the pivot parts reassambled still no joy, then removed wiper arms from their splined shafts and everything looks like it's ok, put 1 wiper blade on an it stops working,also stops working no blades,light finger pressure on linkage rod.have you come across this before? motor gone possibly? any info gratefully receved trev
