by Dave-R (Roppa440) » 14 May 2003 20:25
Now I have had access to the workshop manual (which I suggest you get a copy of because it is a great help) I can see what you need to do.
Yes you need to take off the steering wheel.
Yes you need to remove the rotating part of the column (as described on this board somewhere).
Then you need to remove the turn signal and hazzard switches.
Then you remove the next section of the column just like the last only this bit has a snap ring too.
Then you remove the steering lock.
Then you insert a wire into a hole to release the ignition lock.
You really, REALLY need to see the pictures in the workshop manual to do this right unless you have done this with similar cars before.
