by Johnny-D » 07 May 2001 10:59
The MSD ignition box can be used with your existing distributor. From memory, there is a ground wire to run to your frame and 4 additional wires - 2 that you plug your old (coil) battery lead and distributor leads in to and 2 that (then) run to the coil to give it new firing instructions. You may need to purchase a tachometer adapter to run the ignition system with electronic tach's.
