hello all,
I have been trying to sort out issues with my gauges and at a lost what to do. Both my fuel and temp gauge were dead. I traced the problem to the voltage limiter, and replaced it with a solid state one, now I have constant 5 volts. My replacement temp gauge is now working, but the new fuel gauge is pegged at full. I pulled the wire off the sender by no change, I then disconnected the sender, (purple) lead from the gauge and nothing happened. I then grounded the purple terminal to the frame and still it reads full. I don't know what else other than a bad gauge it can be. Any Ideas? The gauge came used off E-bay.
