Front turn signal/ indicators
Postby cv70chall » 10 Mar 2014 13:39
I have a gremlin.
My right directional works fine- exterior lights flash and dash indicator blinks. The left turn signal is having issues.
Rear light blinks.
Front/ Fender lamps DO NOT
Dash indicator DOES NOT
Yet, the flasher is clicking.
Any ideas where I should start looking on this one?
CVchall70
cv70chall
Re: Front turn signal/ indicators
Postby dave-r » 10 Mar 2014 14:07
Check for high resistance between the lamp housing and chassis ground. I had to run in a grounding wire to each of mine to get them to work well.
Postby cv70chall » 10 Mar 2014 18:09
Will do,
Weird thing is- they were working fine..then intermittently- now not at all.
I was working in the trunk and by the steering column. Could there be anything I could check under the dash?
CVchall70
cv70chall
Postby dave-r » 11 Mar 2014 8:36
You could check the connector below the steering column that comes from the turn signal switch.
Postby cv70chall » 14 Mar 2014 17:18
Dave-
Left Turn signal- you can hear the flasher but there is no dash indicator. Front lamp does not flash but rear tail light DOES.
Right Turn signal- dash indicator, front and rear lamps work normally.
Could it still be the plug at the column?
CVchall70
cv70chall
Postby fal308 » 15 Mar 2014 7:52
Stating the obvious but have you tried checking the left front bulb? Or tried changing it/
fal308
Postby dave-r » 15 Mar 2014 10:18
cv70chall wrote:Dave-
That connector is from the turn signal switch. Because the rears are actually the brake lights there is a wire for each corner of the car.
Left Front = Light Green
Left Rear = Dark Green
Right Front = Tan
Right Rear = Brown/Red
Pink = Hazzard Flasher
Brake = White
Postby dave-r » 15 Mar 2014 10:20
Bad connection from the outside of the bulb holder to ground is still the strongest bet.
Postby cv70chall » 17 Mar 2014 20:41
Found it!
All front lights have solid ground. Checked under the dash and there is a loose wire above the column, so I'll rummage around there and see what I can find. I would imagine it's the light green wire as you suggested.
Ugh..
CVchall70
cv70chall
