Managed to find this under the tree. !!
It goes in next week. I do have a question though. There are two shims located on each axle end. Should I replace these or simply give them a good cleaning?
Thanks
cv70chall wrote:Managed to find this under the tree. !!
Thanks
Adrian Worman wrote:Oh yeah used now I've actuallylooked at the pic
There is a rubber bumper on top of the pinion snubber isn't there? I thought that's what he meant.
Did only Hemi cars have the plate Dave? My 72 has a reinforcement plate welded in that area, would it be the same or is there a strengthening gusset on that part of the floor pan anyway?
dave-r wrote:That is what I used to argue Drew. But Jim insisted that there was EXTRA re-enforcement on Hemi's.
Maybe he was thinking of B-body cars? I am sure I have seen those without any re-enforcement at all.
Eddie wrote:I'm no expert but there is a 'plate' on my SixPack 70 but on my 318 2 barrel 72 there is none. The plate is a curved steel plate around .100 thick and is contoured to fit right above the snubber. I wouldnt worry about it unless you plan on drag racing the car. For handling,,the snubber isnt going to help you.
