Probably a 3.23 open diff. it's very easy to test, just lift the rearend up, turn one wheel, the other should move in the same direction, if  the other wheel turns the opposite way it's an open diff. I would just run what you have with your mild combo. Chrysler used limited slip/sure grip now called anti-spin,,posi is a gm term.
 You can also turn the drive shaft 1 revolution and count how many times the wheel rotates,,this will give the ratio if your centersection doesnt have the tag describing the ratio but probably 80% had the 3.23 8.75 diff in 318 cars. This is what mine was with 318 2 barrel carb. Does this answer yor question? There is a way to find out how healthy the CS is but it involves removing the CS and placing it in a fixture,(easily made by using angle iron,,then placing the ring gear under load by shoving a large screwdriver against the ring gear and rotating it by turning the yoke, then observing the wear pattern on the ring gear(after cleaning the ring gear and using lipstick or the yellow paste they give you in the re-build kits. If it's too high or too low a pattern then either the pinion or carrier bearings or the races are worn and should be corrected to the correct pattern....but as I say this is a lot of work. I would just drain the old lube and re-fill it with quality fluid and run the piss outta it!
 BTW, it might be a cone style sure-grip which is Auburn, clutch style which is Spicer, or open carrier which is the Chrysler made unit. I am pretty sure Chrysler used outsourced limited slip units as described above. I would definitely use  new U-Joints on the driveshaft and new yoke straps,, they are very small bolts 1/4- 24 I think.(DONT over torque them) they will snap right off.(170 inch pounds) or around 13 FT. lbs.
