Clutch Pedal Problem
Postby papasan » 26 Sep 2011 15:50
I was shifting from 3rd to 4th when the pedal dropped to the floor and did not return. After inspection, the fork popped of the throw out bearing of which I put back on. However, now the clutch pedal does not have its normal range of motion and is hard to move. Could a spring on the pressure plate be broken?
papasan
Re: Clutch Pedal Problem
Postby Adrian Worman » 26 Sep 2011 16:13
Sounds like it does'nt it? Maybe the throw out bearing has collapsed or worn its way thru the clutch cover spring blades/forks. What type of assembly, Borg and Beck or diaphragm? Gotta come apart anyway but double check that the clutch push rod from the Z-bar is pushing the fork back squarely and not up or down.
Jesus built my hot rod
Adrian Worman
Postby papasan » 26 Sep 2011 16:55
Adrian - thanks you for confirming my suspicions. I was hoping for something simpler than removing the transmission. All in a day's work.
papasan
Postby Adrian Worman » 26 Sep 2011 22:43
Don't forget to carefully inspect the input shaft for evidence of seizure and galling, especially if you think that the clutch assembly has disintegrated, could be shrapnel anywhere :shock:
Keep us informed when you pull it out and inspect it :idea:
Adrian Worman
Postby papasan » 27 Sep 2011 18:45
Thanks. That happened to me back in 79 when I blew up the clutch so bad the disc disintegrated and tore through the pressure plate springs. Good thing for the bell housing. :D However, in this case I was granny shifting so I hope there isn't any significant damage.
papasan
