Eddie wrote:Hey guys, I was pokin underneath the Challenger today and I was thinking,, is this thing gonna hold 600+FT. Lbs. and my manual Keisler RS 5-Speed with 17X8 Drew sized Rubber?
fbernard wrote:I am in the process of buying a TF727 with a GV overdrive.
dave-r wrote:fbernard wrote:I am in the process of buying a TF727 with a GV overdrive.
I was years ahead of you there.![]()
Eddie that axle sounds pretty strong to me. My axle survived with some strip action and a lot of street abuse and i was still running the original shafts, suregrip, bearings etc.
Thanks Bro! Thats what I'll do then! I can get a new Nodular Iron '489' case from Dr. Diff built with a Detroit True-Trac, US Gear 3.55 Ratio, 1350 U-Joint for around 1285.00 plus the stronger axles for another 300.00 bucks. Time to save! Should be a strong butt!drewcrane wrote:I didnt see this post, but I have 4 different cases 2 are 489 cases one has 3:91,3:55,,and currently I have 3;23,S ,The clutches are bad so only one wheel spins, but I did replace the stock axles with Strange axles ,(did that 4 years ago)I just didnt trust the stock axles, I have seen them break, but the 8.75 rears stay together ,and with the OD it might take a little stress off the rear
Eddie wrote: I can get a new Nodular Iron '489' case from Dr. Diff built with a Detroit True-Trac, US Gear 3.55 Ratio, 1350 U-Joint for around 1285.00 plus the stronger axles for another 300.00 bucks. Time to save! Should be a strong butt!
Adrian Worman wrote:drewcrane wrote:I didnt see this post, but I have 4 different cases 2 are 489 cases one has 3:91,3:55,,and currently I have 3;23,S ,The clutches are bad so only one wheel spins, but I did replace the stock axles with Strange axles ,(did that 4 years ago)I just didnt trust the stock axles, I have seen them break, but the 8.75 rears stay together ,and with the OD it might take a little stress off the rear
I got me a used SureGrip diff unit that I wanna stick in my 8 3/4 rear, I haven't stripped it yet but when I do how do I tell if its toast? Its a cone type I think, seen an article on how to breathe new life into it, just thought it would save a load of stress if I knew what to look for when I inspect it.
