Adrian Worman wrote:Ta Dave
From what I've seen (I have a Tremec 5-speed), 6-speeds do not fit without extensive tunnel work and trans crossmember rework.
The Tremec is OK for street and road-racing. It does not like to shift far over 6K RPM at full load, however. Get it from Keisler or Classic Mopar 5-speed (I did - they are called Hurst Driveline Conversions now :
http://www.hurst-drivelines.com )
I had a look at Viper T56s before I bought mine, I don't think those will fit without work either (if it was easy, there would be kits - there are for GMs and Fords, so I think the trans tunnel shape is the limiting factor).
Too bad though, for the T56 is a good transmission and can be made even better (lookup Transzilla).
For even tougher transmissions, there's Jerico and Liberty (if you want to drag race with a stick). If you're going that far, cutting a crossmember or fabbing up a new tunnel is in order...
One last thing : if you get a Tremec, unless you really plan to use the 5th on the highway only (cruising at 2400 RPM), don't get the .64 final ratio, get the .80 (that's the "road-race" TKO-600). The .64 really feels like a 6-speed without a 5th gear (going from 1.0 to 0.64 is a really wide spread on a racetrack).
[Or if you really want a .64 final ratio, get a .80 and we'll swap!
