I need to replace my rear end with a correct 3.55 sure grip with the correct casting numbers. Can anyone tell me the correct casting numbers for a TA rear end?
Also, do you need a puller to remove the axels? Will I need to change the axels and/ or the draive shaft, or are they the same (I have a 741 case now with 3.08 gears.
