I dropped the trans today, its  killer of a one man job especially when trying to work between the headers and exhausts.
The exhaust from the headers back is one complete system with a welded in cross pipe and welded hangers etc  with no u/bolt  joints whatsoever clever engineering or what.
The 727 is a numbers matching unit but must have had work carried out at some point in its life as gaskets with the trade mark Transtec can be seen on the rear housing joint.
The TC looks quite new with the only I/D mark being on the ring gear 47339k05 & CH RG 130.
When googled the only info on this is that the ring gear is a Sonnax part
Chyrsler Ring GEAR 130 Tooth.
It looks as if it is an 11" TC, the I/D of the ring gear is actually about       11 1/4"
The Flex Plate looks ok also with no cracks or warps visable.
I am a little disappointed with this as I hoped something would jump out and bite me.
The centre shaft (Drive ?) has about 2mm of free sideway play at the bellhousing end. I do not know if this is normal.
The circular ring just above the larger splines in the TC can be rocked sideways and results in whatever it is attached to making contact with the inner wall of the casing casing. The hollow sound it make be it low sounds very similar to the clanking noise that started this saga.
I do not know if this part of the TC is supposed to be able to move as it does.
If the TC is the faulty unit I am stumped to know what rpm stall it is as I expected this to be stamped on the unit along with the manufacturers name but it has neither.
Sorry if the photos are to big I am still getting to grips with this computer biz.
Cheers
