Tranny Question
Hello,
Would I be right in thinking that ATF runs out of the torque convertor and into the pan when the car is not in use ie overnight.
Reason is that after sorting out the ignition problem via another thread with Dave,s help another dinger has manifested.
After leaving the car overnight or longer I would normally start it and leave it warm up for a couple of minutes before engaging reverse or D whichever is the case.
Yesterday when reverse was engaged a lot of clattering came from the bowels so I shut it down and left it for an hour or so before restarting.
It still clattered in neutral but quietened down as the engine warmed.
I thought I had dropped a bigend or similar, but the engine idles and runs fine with no adverse vibrations.
I took the car for a 10ml drive and only heard a slight rumble from below once when under load.
Back in the garage I drained the oil and checked the magnetic bung for unwanted guests and all was clear no slivers etc.
Refilled with new oil.
I removed and checked the plugs and all were burning fine.
I left the car on stands over night.
Started it again today and the same rattle is there so under I get with the stetyscope screwdriver to my shell like listening for where its emminating from.
It seems to be coming from the rear of the sump closest to the bellhousing you would think a marble was being thrown around in the oil.
It quitens and disappears as the engine warms and gets a couple of revs so the bigend or similar is a non runner methinks.
I am of the opinion that a strator blade or similar in the T/C has broken loose and rattles like mad when the car is started cold with some ATF not being present but as the fluid runs into the T/C it acts a a buffer and stiffles the racket.
The noise is being transferred up the crankshaft making it sound as if it is coming from the sump.
Am I nuts or what ?
Am I nuts or what ?
