I got the verter & box back in on Wednesday and started the car with the rear wheels on stands to run it in all gears to allow the fluid to reach all areas required.
The rattle did not manifest so I assumed every thing was ok, she spun wheels in all gears via the slapstick which now also works.
The car idles at about 1000rpm and seemed to labour a little when put into D nearly stalling I can only hope the verter is 2400rpm as sold.
Yesterday was D.Day to road test. Only out of the garage and something seemed to be binding with the steering pulling to the right badly. Stopped the car in neutral and tried to push same not a chance.
Back into the garage and raised the rear both wheels spinning freely, raised the front and the passenger wheel was locked solid with the pads wedged to the disc. The brake peddle was still hard
so I assumed that the proportioning/metering valve or master cylinder had malfunctioned not allowing the fluid to return so I went to open the bleed nipple to relieve the pressure.
Bleed nipple me arse as this was non existant having been broken flush with the caliper housing a long time hence.
The caliper mounting bolts had to be removed to prize the unit of the disc.
Pumping the peddle forced the 2.75in piston out to show a little corrosion + crude in the cylinder so with no way to bleed the system properly and from expierience knowing that the sheared nipple stump will be a pig to remove I ordered 2 new calipers, hardware & pads etc.
Still have to source a proportioning/metering valve but the callies are a start.
This old Chilly is turning into an educational trip
