The converter looks like what we call in the industry an 11" converter by looking at the width of the ring gear. As I recall, that ring gear will measure just about 1" from the top of the ring gear teeth to where it is welded to the body of the converter. A 12" converters ring gear will measure about 1/2".
The numbers on the converter are the factory numbers, and to the best of my knowledge have never been decoded by the aftermarket. Chrysler used both 11" and 12" converters behind all of their engines. I've seen 11" converters behind 318, 340, 360, 400, and 440 engines. The same can be said for the 12" converter. What you may be looking for is a 12" low stall converter, balanced to match your engine. Engines came with either a steel or cast iron crank, and the converters must be balanced accordingly.
Put the wrong converter in and you end up with a badly shaking car.
Are there weights on the engine side of the converter, and if there are, how many, what size, and what shape are they in. Factory weights are on the engine side of the converter.
From your picture, the converter hub (goes into the transmission pump)looks worn, and if the converter is rebuilt(????) they never replaced the hub. Remember, a converter is a sealed unit, and over the years, I've seen many REBUILT, "quote unquote", converters that had a new paint job and that was all that was done to it. Unless you know the company that does the rebuilding you never really know what has been done inside the unit.
Trying to find a bullet-proof converter will be very difficult, as any and all converters can and will break given the right circumstances. What you should look for is a converter that has been furnace brazed, has torrington bearings in it, and also has a steel stator inside. This would give you a very strong converter. The usual aftermarket converters would be at best built only to factory specifications. Good for normal replacement and slight engine improvements, but not much else. High horsepowered cars require the proper converter.
Send me a private email and I'll see if I can help you.
Please give me all the details you can about your engine, steel or cast iron crank, internally or externally balanced, camshaft specifications, the rear axle ratio, and what you will be doing with the car. All this helps get you the proper converter for your application.
transman
[/b]
