One thing to keep in mind, when replacing a bushing IT MUST GO IN STRAIGHT.  When I worked in the transmission business, I saw a lot of people putting bushings in with the wrong tool.  Usually they were not in correctly.
When you have your bushing, do one of two things.  Either have a transmission shop install the bushing for you, or find a tool rental store that rents such a tool.  The outfit I used to work for has a website
www.tcsproducts.com .  There you find a link for misc. tools and there is a picture of a bushing driver set.  Not that you need a bushing driver set, but you can get an idea of what they are.
The seal and bushing by the way I think are the same as the rear extension housing bushing on a TF727 automatic transmission.  Take your seal and bushing to a transmission shop and make a comparison.  The Chrysler dealer will also probably have them in stock.  Nothing special, just a babbit bushing and a normal seal.
transman
