the car has a 360 and 3 speed stick shift, will I need the bell and fly wheel too
Goldenblack440 wrote:The flywheel should be able to be used. Hopefully its a factory manual? Then it will have the proper factory balanced flywheel that is for the externally balanced 360. Hard to get down here. I had an A230 (the 3 speed you have) and i am pretty sure the bellhouse is the same as the A833 4 speed. Even the drive shafts are the same as the extension housing is the same length and uses the 4 speed/727 yoke.
the A230 gearbox was pretty strong. They specified it for use behind the 383 as well so its got my respect. Pity it only had 3 speeds....!
