Hello guys.
I've just installed a new transmission coooler by B&M with fan and switch included that works at 175ºF.
The transmission gauge temp shows up to 210ºF once arrived at home due to the low speed and climbing way to home.
I checked with a laser temp when I saw that the fan didn't work and my surprise was when the cooler was around 100ºF (inlet and outlet) the transmission pan at 180ºF and transmission sending 200ºF.
The oil lines from trans to fan in front of the car (near the water radiator) have 8mm diameter.
Is this enough? Maybe I need thicker tubes from trans to cooler, but I 'm not sure about it and I don't know about the company to purchase it.
Thanks.
