I have a question for Transman or Dave...I accidentally dropped the park rod to shifter shaft circlip (on the valve body) into the trans. Its upside down, out of the car. No amount of coaxing, compressed air or magnetic assistance can get it out, so it must be stuck somewhere in the top. If i remove the front pump assembly, will that give me a clear view into the body of the trans? if yes, Next question is... IS it easy to remove or do i need a special tool or puller? I noticed the two outer holes are threaded - they look like they are used for a puller?
This is the second park rod circlip i've lost, very annoying.!
