burdar wrote:When do you feel the vibration? Is it just on acceleration or is it there while cruising? Does it increase with vehicle speed? If you put it in neutral while moving down the road does it go away? You said that you have had your tires balanced...have you checked them for flat spots or if one of them has a belt that is separating?
I had a vibration after putting 18" wheels on my Stratus. I had them balance a few times but the vibration was still there. A shop accidentally ruined the wheels and had to buy me knew ones. Then the vibration was gone. I must have had a bad wheel the whole time. Make sure one of your wheels doesn't have too much runout.
charliek wrote:burdar wrote:When do you feel the vibration? Is it just on acceleration or is it there while cruising? Does it increase with vehicle speed? If you put it in neutral while moving down the road does it go away? You said that you have had your tires balanced...have you checked them for flat spots or if one of them has a belt that is separating?
The vibration is there above 55 mph and gets worse when speed is higher.If I put it in neutral it does not go away. If I rev the engine in neutral while not moving there is no vibration. It starts at around 55 and get really bad at around 70. the tires are new and the car did not shake right before restoring with the same tires. I feel it pretty severely through the clutch pedal.
charliek wrote:Thanks for all the advice. I eliminated tires since they were new and I recently had them rebalance to double check. I thought the trans was angled slightly down so I shimmed it up and it seems to line up with the driveshaft now. I just dropped my driveshaft off at Mr. Driveshaft to check the integrity and balance. Will let you know.
drewcrane wrote:ok dave is right i ended up slotting my trans mount so i could get the trans angle down, i found later model trans mounts that had the mounting holes about 1/ 2inch lower that my mount that came on the car, again your not alone i still have an unwanted vibration in my car but slotting my trans mounting bracket did reduce the vibration somewhat so i know i am going in the right directiondo you have an angle finder? if not you can get one at a hardware store
