HI, does anyone know if a 74 valve body will work in a 71 904? I can see there are some visible differences, mainly in the area of how they attach things on the valve body. It will definitely screw in etc, just wondering if the springs and internal workings will be the same so it can go straight into the 71 box.
Also, what is the best fluid/solvent to soak and wash out a valve body with? I didn't want to soak it in petrol, just in case here were rubber seals inside. I was thinking of water based degreaser, then heaps and heaps of compressed air everywhere to blow it out, then soaking in clean trans fluid, then another blow out.
Does that all sound OK??
thanks!
