Moparman1972 wrote:SO update: I have acquired the bigger pieces required for the conversion, such as the tunnel hump and the z-bar and clutch pedals. I also found a big block bellhousing in my barn for this transmission! It was in the backseat of my Cuda...
 That car will be dug out someday soon...
Looking on sites like Yearone and Paddockparts, they list a multitude of washers/clips/rods. Does anyone have a shot of the linkage from underneath? I have no idea what it looks like all together and I won't cobble it together without knowing that I'm hooking it up right. I have all sorts of pieces lying around in boxes, so maybe I'll even get lucky and have some of the linkage.
Lol doing a search, it looks like this question was asked a few times but never answered with pictures.....perhaps a sticky with pictures of transmissions/linkage setups would be helpful?
Cool! Check that Bell pretty good Dylan. Mine has what I call 'fissures' in the alloy. Under load, I dont know if it will be ok or not. So I bought a double drilled Keisler for 299.00 it's double drilled for any starter or clutch you want to use. 10.5 or 10.95" 143 tooth ring gear or 130 it doesnt matter. It's constructed from a Titanium/alluminum alloy and supposedly twice as strong as the stock bell. It weighs 15 lbs. If your's is fine disregard this, just an option for ya. On the subject of linkage, my original shift rods were bent, so I bought a set from Brewers performance, Wayne Brewers place, he races S.S. and Nostalgia classes and really know's his stuff. His shift rods are Chrome-Moly steel and precision bent. I then used a McCleod Street Twin. It will hold up to 800 ft. lbs. reliably! I hate sloppy shift action! I wanted a strong well built clutch that could take a lot of abuse. It's not the cheapest setup and I now you are on a budget, but sometimes it 'pays' to play' and clutch changes arent the funnest thing to do under the car. Another thing that is vital to the street twin is clutch 'runout' make sure you check it for concentricity and a square bellhousing face before you bolt it all together. I think the runout specs should be no more than .003,,,the Keislers Bell's are guauranteed to be within .001 but you should be OK after checking, and if need be sent to a machinist to true that surface. (This is vital to ensure a decent clutch life), if it's 'off' it will eat the clutch in no time. I also would have the thrust clearance on the #3 main checked very carefully, the tighter the better, mine was .006, there HAS to be some but anymore than .010 will cause the bearing to wear at an alarming rate. The linkage small parts,(Plastic spacers, bushings,clips) can be had at Mancini Racing or Brewers Performance or any major mopar parts supplier,, I'll try and get you some pics of my underside linkage setup, but it will take a few days.
 Glad to hear you are using a 4-speed!!
