Then I would be build as much torque into the engine as possible with a nice flat torque curve. In other words, a near stock setup with good exhaust, strong clutch, steeper rear end gears like maybe a 3.91 would be a good choice.
But then again, a swap to a four speed wouldnt be that costly, along with a 3.91 gear, vacum Holley or probably stock Carter 600 CFM and some thicker torsion bars, with rear sway bar wouldnt be that much more expensive than 'stock' and corner a lot better than the factory setup with minimal cost. I didnt mean a 'high dollar car' Barc, just something that will improve the driveability and outperform the stock setup without detracting from the original design too much. Drew's car comes to mind, then the next level would be something like Daves or mine, then Fabiens 'Mondo' setup,(which if I had the money and guts I would emulate)LOL
