by Goldenblack440 » 30 Mar 2009 17:17
Part 2 of my above post, sorry if its boring~! - i am having big dramas with the seal. I bought two seals originally, one for a 904 i was building on the bench. This seal went in no problems and the valve body/shift shaft slid in nicely. Easy when its on the bench. But in the car it has been a whole different story. The second seal installation proved very tight, one edge of the rim would not go in easily using a socket. So i tapped with one edge of a hammer. Went in easily, but now i found the seal was slightly deformed, even though the seal lip was perfectly round. I thought i'd try putting in the valve body anyway, just fill with oil and see if it leaked. Putting in the valve body with plenty of oil on everything, i could not prevent the seal lip from turning outwards. In the end the seal was wrecked. Popped it out and rushed to the bearing place for another seal. The one they supplied is slightly larger (about 10 thou larger) so now i have to get some wet and dry and open up the trans seal bed and smooth out the seal diameter. If this seal gets damaged, its off to a transmission place for another seal. What a nightmare!
