Actually Jeff, it's the torque that does the damage, it always is. I dont think the alloy,(alluminum), shaft will be harmed either, but the Chrome-Moly steel is the strongest. Thats why they dont have a guarantee on the alloy. Racers are totally obsessed with weight. or the lack therof. For good reason, less weight on the vehicle, less stress on the driveline components,, plus better reaction time from less rotating inertia and mass. But if you are contemplating 'squeeze' then I would opt for the steel shaft and 1350 yokes with U-joint style straps which are standard equipment on the 1330/1310/1350 u-joint series I think or at least the fasteners are much larger. This means you're rear yoke would have to be swapped out for the larger piece. Combined with a DS loop, you should be set for max launch!!
 Keep us informed, freaking madman! I love it!
 The site Fabian placed up is awesome, they have some very nice components, the yokes are sweet! Jeff, did you check out the hardware?
