dave-r wrote:This is a great thread. Thanks for putting so much input and detail into it. I am sure this is goingto help a lot of people for years to come.
Thanks Dave- yes, Richard Ehrenberg (editor of US Mopar Action) asked me if i wanted to do a tech article on them, although i have a feeling he was half joking. Still, even half joking its a compliment from him. I have his tech articles on CD-ROM and told him there was nothing at all on the slapstick.
Moparman- you are quite correct on the second point i feel. I fully expected the tooth on the plate to wear but under close inspection they both seem unworn. However when new, i would assume that this tooth fits perfectly into the V notch on the steel block. As you can see from the pics of this, even my least worn one does not fully reach up, however it does more so than the other one, meaning that it may also not be long till its beyond hope. It is actually the metal block that gets thinner, making the V less pronounced, therefore giving less "meat" for the tooth to grip into. These could be manufactured by a competant machinist but i dread the cost- you would have to supply him with a new one to go off. In the years of operation, i dare say the 'ol slapsticks got a fair workout on the street- getting banged (no pun intended) in the heat of the street race. In this situations its quite possible that the tooth Moparman is talking about did get worn as it takes all the force from 1st to 2nd gear. So i can only go on the two i have, looking at a dozen or so would give a better indication of what wears and what doesn't. But anyone with a dozen slapstick mechanisms would be a wealthy man for sure.
I am just adding this bit now, after looking at the Slap in operation: i see what you mean about the top of the tooth getting worn shorter but in my ones this does not happen as the steel block springs up away from that plateau as soon as the tension eases of the tooth, so it rides over the top by about 3-4mm
