Rear End Switch
So I dug up an old 8 3/4 rear end that was in my barn. It had a posi chuck in it, so I figured I'd do a quick swap for my chuck this afternoon. The rear end was out of a 70 Cuda, so of course I didnt really measure anything beyond making sure it was the same housing. I got my car up in the air and unbolted axles and everything, (thank god didnt crack the seals, that would have been a hell of a mess for nothing), but when I pulled the yoke off, it was different splines. The yoke on the posi rearend was coarse splined, and the yoke on my car was fine splined, and on top of that, the width of the yokes was different across the inside by half an inch. I have to EDM a snapped bolt out of the posi yoke, too, if I'm to use it.
Should I use a different size U-bolt if I'm able to re-thread the posi yoke? Should I be looking for a different yoke or driveshaft? Also, are the axles going to be the same for both rear ends, or will they be splined differently too? In that case, I would have to swap axles with the posi rear too. Just looking for suggestions before I go and bugger things up again.
