plum-crazy wrote:The car weights 1650 kgs without driver + 80 with me inside.
If the engine produce about 630 hp at flywheel I think I will arrive almost at red line (5900) at 1/4 mile with a 26" tires and 3.55 ratio.
A friend of mine, in a 1973 'cuda, with a 3.55 Truetrac, a stroked small-block (416ci) giving 500HP, and a Tremec 5-speed manual transmission, did 12.59 at Santa Pod this year, on 26" x 8.5" slicks (Mickey Thomson 3052).
He only used the 3 first gears, redlining at the end.
If you have a Torqueflite (2.45:1 first gear, 1.45:1 second gear, and 1.00:1 third gear), I don't know whether it's better to plan on using all 3 gears or just 1 and 2 (Dave will know).
You will need a converter with a high stall speed, too.
All I know is you may want taller tires for the street. With a 1.00 final transmission ratio and a 3.55 rear-end, you'll be at 110km/h at 3000 RPM.
That's acceptable for cruising, if you dont do too much highway.
