 by dave-r » 23 Apr 2008 13:06
			Hard to put problems into a foreign language i know.
I think you are saying you have damaged (stripped) the threads on the wheel studs or the nuts by cross-threading the wheel nuts?
Is that correct?
If so you need to replace or repair the damaged parts. Replace would be better. But if the damage is slight and on a non-critical area like the end of the stud then you can repair the thread with a tap and die set.
Some of our cars came with left hand thread on the left side of the car. But most have been replaced over the years so that they are all right hand thread.
Right hand threaded wheel studs are 1/2"-20UNF x 1-19/32" with .673" knurl diameter.
RH thread lug nuts are 1/2"-20UNF
