From the factory, Chrysler made mainly 2 sizes of converters. An 11 inch unit, and a 12" unit. The 12" unit has a narrow ring gear on it (for sake of discussion cause I'm not a work to measure one) around 1/2". The 11" converter has a wider ring gear of around 1". These converters were used in all applications: everything from the leaning tower of power with a 904 to the big/small blocks with the 727. The hemi to the best of my knowledge is the only big block that had it's own performance converter. We've had at our shop 440 converters from various vehicles, including the 6 pack ones. Internally, (if its the 11" model ) they are identical to any other 11" converter for the 440. The same holds true for the 12" unit.
340' s are the like the hemi. They had their own converter. Chysler performance parts at one time had what they called the "J" converter. I've never seen one, but I've heard that they ranged in size around 10". Others said the converter was a 9.5" converter. They may have had others listed in the performance parts catalog, but I don't have any old performance catalogs anymore.
A 10" converter with a big block should stall around 3200 to 3500 rpm. This is pretty much the industry guide line. Of course, these stall speeds can be increased or decreased by the manufacturer to match the power band, engine design, etc.
In small block form, you should expect to see 2500 to 3000 rpm.
A modified 11" converter should stall around 2600 to 3000 rpm with the big block, and between 2200 to 2600 rpm in a small block application.
Engine design and camshaft power bands have a huge impact on a converters stall speed. Pay very close attention to what the cam maker recommends for converter stall.
In race applications of course there are many other factors to effect the stall speed of any converter; rear axle ratios, tire size, etc. There are no on the shelf race converters made by anyone. As each race car is different, these converters must be custom designed for each specific appication.
The converter in the photo looks like a TCI unit.
Hope this helps.
transman
