ok my set up has a bracket that mounts to the carb stud , it finally worked loose , and eventually pulled the stud, there is a set screw on the bracket , but it still moves, i dont like putting that much force on a carb stud in aluminum manifold,a carb needs about 15 lbs of torque, and this bracket requires more than that, i have found a much better bracket and i will provide photos in the coming days , it is too cold out side now 20 degrees f, but i think i have a fix , im not sold on lokar for everything , likt there flexible trans dipstick, it rubs against the casing when i pull it out making for an inaccurate reading, so i put the stock back on ,but i will fix this an d show photos cause i like the cables a little better that the linkage
