Hi. I could use some recommendations what ring and pinion to use for 8 3/4" rear-end on my setup. Driving on nice sunny days and ~1000 miles a year on highway with 75 mph limit. Fuel economy is important, but I'm after performance as well just like we all do.
This dyno slip is from same type of 6.1L, but not from my engine. Both are stock except some modifications to intake manifold and 3" exhaust. If I end up swapping cam then this info is of course more inaccurate, but should still give some ballpark figure I hope.
Transmission is 5 speed automatic (545RFE) with 1st 3.00, 2nd 1.67, 3rd 1.00, 4th 0.75 and 5th 0.67.
I tried to put numbers in excel and for example with 4.11 gears I should end up with same final drive ratio as with 2.76 using 727 transmission?
From factory these 6.1L engines come mated to 5-speed auto transmission (W5A580) with 1st 3.59, 2nd 2.19, 3rd 1.41, 4th 1.00 and 5th 0.83. Factory rear is 3.06 with that engine and transmission combo. Stock tire outside diameter is 29".
				 by oke » 11 Dec 2007 22:03
 Just my two cent's worth.
 Just my two cent's worth.  Pat
  Pat
