When you replaced you clutch with the one Mancini recommended, what else did you change?
The new flywheel is mandatory if yours is cracked. You may have yours resurfaced if it's still good (I guess it's probably a little blue).
If you launch at 6K again, I hope you have a SFI flywheel and bellhousing, and good flywheel bolts...
What you should consider :
- New flywheel bolts (for example Mopar Performance P4529113).
- New pilot bushing, or better, bearing (the pilot bearing can be installed over the bushing that's further down the crank hole). Mopar Performance P/N P5007051. Unless you already installed one last time.
Once the transmission is removed, check for side play on the input shaft.
The job itself (changing the clutch) is easy enough, but there are some important details. If it is removed (can be done without removing it), the bellhousing must be exactly re-centered over the flywheel (because the transmission itself is centered by the bellhousing center hole). This is a 0.005" job. Complete procedure described here :
http://www.moparchat.com/forums/archive ... 04619.html or better, in your Service Manual (with a couple pics).
You may need a set of offset dowel pins (P4120383).
The tooth count depends on your bellhousing, since the starter position is not the same (143-tooth flywheels are larger). From what I read in the MP catalog, 143-tooth would be the Hemi flywheel with the 10.95" clutch.
All flywheels in the current Mopar Perf catalog are 130 models. So I guess it's safe to say you probably have a 130-tooth flywheel.
Since I already have the Mopar Performance catalog on my lap, here are a few more refs :
Flywheels :
P4529142 : steel flywheel (30 lbs, good for launches)
P4876047 : Race steel (18.5 lbs)
Be sure to re-set the throwout bearing position on the clutch rod (so it's not in permament contact with the flywheel), and maybe install some sort of pedal stop if you change the flywheel thickness (there is almost a 1/2 inch difference in thickness between the 18 lbs and the 30 lbs flywheels).
