				Big or small
10 Dec 2001 15:54by Von
				I'm embarrased to ask, but is there a difference in a "big-block" and "small-block" 727 and a "big-block and "small-block" four speed?
				Big or small
10 Dec 2001 21:13by dave-r
				Bell housing is different. Some of the 4-speeds are stronger than others. For the 440s and Hemis I would think. The auto boxes will have lighter piston and clutch springs. Fewer clutch plates.
Other than that I think they are all the same?
				Big or small
11 Dec 2001 0:39by Mike
				good question Von...i have wondered the same thing.
				Big or small
11 Dec 2001 1:53by Von
				so would a four speed that was originaly paired with a 340 bolt up to a big block? what would I have to change?
				Big or small
11 Dec 2001 9:54by dave-r
				I thought I already answered that. The bell housing is different so you need a big block bellhousing to physicaly bolt it up.
Also if the 4-speed is replacing an auto trans you need a manual type crank drilled for a pilot bushing or a auto trans adapter bushing.
I don't know which internal bits would be weaker but chances are nothing would break.
				Big or small
24 Jan 2002 13:35by larryp
				Many of the big block 4 speeds were 18-spline input shaft whereas all of the small block were 23 spline. The physical outside dimensions and configuration of these transmissions is the same, so the differing parts are the clutch bellhousing, clutch assembly, and flywheel.
				Big or small
24 Jan 2002 17:46by dave-r
				Good infomation. Thanks for that.
