I've been through new u-joints , drive shaft, balanced ,.....the whole bit, 5 TIMES"
I'm down to adjusting the axel angle and the engine and transmission angle, I'm going to have the angle of the drive shaft lazer plotted with relation to the angle of the transmission and rear end. (i.e. is the rear end angled down and transmission angled down, the result would be a "U" shape -vs- the differential angle is down, transmission up, forming an "S", obviously you could reverse the last order up or down to arrive at the same "S".
This has been a maddening process
Anybody been through the same crap????
Help!!!!
 by zzubzero » 29 Aug 2007 2:18
 ) I think the pinion U-joint needs to go up. ????
