Hi, I have 904 trans that was working fine till last week. First i started to hear some noise like metallic pinging under acceleration in drive, later probelms with kickdown has started, when i put full throttle it  reduce so much that rpm goes mor than 7000. When i change gears manualy it takes around 2-3 seconds for trans to shift gear since i move the lever, this happens also when I try manulaly reduce gear, 2 secs of hesitation and the gear goes down. During normal drive in D works good changes gears normaly but under hard acceleration is bad. My engine puts around 400 hp so maybe this was to much for old transmission.
Any suggestions please ? I think that if i am going to rebuild will be better to go for 727 and buy another one. I will also change the converter so if you have suggestion whats the best please let me know.
		 by Wojpi » 08 Jul 2007 19:37
