Anyone that races their car or does burnouts in the street or on the track should read this.
http://www.forabodiesonly.com/mopar/sho ... php?t=2167
airfuelEddie wrote:For you 727/904 guys here is an article that contains a great tip for increased durability using factory/aftermarket parts, and helps to keep that tranny "together" as long as a 4-speed!Check out those different spline angles.
airfuelEddie wrote:The scary part is, as the article states, it all slips together just fine, then the wrong angles serve as a perfect cutting tool then boom!Good to know if your contemplating using Heavy Duty Chrysler parts in your build-up!
