				How not to have your transmission explode
10 Jun 2007 15:03by dave-r
				Anyone that races their car or does burnouts in the street or on the track should read this.
http://www.forabodiesonly.com/mopar/sho ... php?t=2167
10 Jun 2007 15:12by Eddie
				Good read Dave. In my transmission class at tech school we studied the sprag and it's components. It looks eerily similar to a fragmentation grenade as far as the individual metal sections that come apart and leave a swarth of destruction. The stock OEM components arent designed for 18k RPM,(3x mainshaft speed). I would use H.D. parts at a minimum! Glad I have 4-speed with SFI components and billet flwheel also SFI! You automatic guys have way to many worries!
10 Jun 2007 16:00by dave-r
				I thought the guy expained it really well and simply enough so that even I understood it at first read.
				how not to have your transmission blow up
04 Jul 2007 21:51by bakerman
 good article dave.i had a turbo action cheetah man. reverse vb fitted to my 904 which dosen,t have engine braking in first. its on a 340.i dont race the car but i like to have some fun every now and then if you know what i mean.i tend to pull to a stop in 2nd anyway.is this ok do you know
05 Jul 2007 7:31by dave-r
				The key point in that article is you can only damage the sprag in 1st gear.
"Start your burnout in 2nd, and shift to 3rd. When on the street, repetitively getting in and out of the throttle while in 1st gear can damage the sprag."
05 Jul 2007 18:44by bakerman
				thanks Dave.just been looking on the Turbo Action site and they do a manual valve body thats street friendly with breaking in all gears,stock shift pattern.part #17675.
24 Sep 2007 21:24by drewcrane
				i had my sprag go and i got out of it and saved my behind,thanks dave i didnt know the 1st gear thing good advice, the whole trans. twisted inside the case , what a bang, and clunk that was.
				Exploding TF'S.
03 Oct 2007 16:26by transman
				Go to my companies website
www.tcsproducts.com
Click on the on-line-store button, go to MOPAR products and click on the 727 page.  Scroll down to any of the direct drum pictures and click it on.  Enlarge the photo.  On this page we have posted the results we had from an independent test we did on these drums.
transman
03 Oct 2007 18:51by Eddie
				Thanks transman! Great read and very informative as well as eye-opening! Looks like the TSC  billet alloy alum drum is the ONLY way to go for high horsepower apps.
06 Oct 2007 8:35by dave-r
02 Nov 2007 18:48by Eddie
				For you 727/904 guys here is an article that contains a great tip for increased durability using factory/aftermarket parts, and helps to keep that tranny "together" as long as a 4-speed!
  Check out those different spline angles.
02 Nov 2007 18:50by Eddie
				Last page.
03 Nov 2007 11:11by christer
				airfuelEddie wrote:For you 727/904 guys here is an article that contains a great tip for increased durability using factory/aftermarket parts, and helps to keep that tranny "together" as long as a 4-speed!
Intresting reading, Eddie. Thanks! It was new to me.
03 Nov 2007 12:20by Eddie
				Thanks Christer. The scary part is, as the article states, it all slips together just fine, then the wrong angles serve as a perfect cutting tool then boom!
 Good to know if your contemplating using Heavy Duty Chrysler parts in your build-up!
03 Nov 2007 17:50by christer
				airfuelEddie wrote:The scary part is, as the article states, it all slips together just fine, then the wrong angles serve as a perfect cutting tool then boom!
I agree. It is all very treacherous. I would fall into that trap 11 times out of 10. I wonder why they have changed the slope of the splines? Was it mentioned in the article? Maybe the slope used nowadays is cheaper to produce?
03 Nov 2007 19:21by Eddie
				I think it has something to do with the strength of the spline itself as the angle changed.
03 Nov 2007 19:42by christer
				airfuelEddie wrote:I think it has something to do with the strength of the spline itself as the angle changed.
Maybe. Is there anyone who knows for sure?
03 Nov 2007 20:04by Eddie
				The article states that the closer the angle of the spline becomes to a true radius,(which means a gentle curve much like a camshaft lobe), the stronger the shaft becomes. So Strength has to be the reason.
