Hi,
Who can tell me what the purpose is, of the column lock linkage for a 1970 challenger four speed.
I know it locks the column, so you can only remove the key when in reverse........
But Why????
Thanks
Antoon
Thedeputy wrote:And what if some kid gets in the car and accidentaly starts it? Then the car is in reverse and will start to move?
How does this linkage work on an automatic car?
Antoon
Thedeputy wrote:I've also learned to always start a manual car in neutral without the clutch depressed. That way the gear oil gets thrown around the gears before you drive away.
Antoon
Thedeputy wrote:Sounds resonable that the government had a say in this issue.
I will follow your advice with the clutch/start issue. Anybody got a spare clutch safety switch??
Antoon
dave-r wrote:Crickey!![]()
I never did find out how my (quite new) thrust bearing wore completely away within a few thousand miles. On my AUTOMATIC trans.![]()
But I do suspect something was up with the convertor.
I guess there is not enough pressure in a 2000cc or less Euro clutch because I have never had thrust wear on these engines.
