4 speed conversion
Postby mike » 03 Dec 2001 0:37
how much would it cost to convert from an auto to a four speed? are there any major problems with doing this or can i just drop it off at a tranny shop and say "do it".
thanks
mike
4 speed conversion
Postby frank » 13 Dec 2001 4:59
wow i am surprized no-one has responded to this,first off you need a pilot bushing installed on the engine block(very important) i have a 4spd you need a "tunnel" for the trans to fit from what i have found(i know there is a hump there for the automatic but someone told me it wasnt enough for a manual to fit) as well as the inside parts - the service manual for 70 gives a good description of the clutch pedal and its components also i think you would need to weld in a spot for the over-center spring to sit on, the outside(engine bay)a z bar, i think the driveshaft would need to be a different length too. oh one last thing the 70s came with was a reverse warning light(not sure about the other yrs) it sits on the pass side of the ash tray, hope this helps?
frank
4 speed conversion
Postby mike » 13 Dec 2001 15:51
thank you for taking the time to respond. good info.
mike
