 by dave-r » 24 Jul 2006 7:41
			There were 4 types of centre sections (diffs).
You can tell them apart from the last three numbers cast into the drivers side of the pinion.
657, 1 3/8" pinion ('57-'64);
741, 1 3/8" pinion ('65-'74);
742, 1 3/4" pinion ('57-'68);
489, 1 7/8" pinion ('69-'74).
Of these the best are the 742 (Shimmed preload) and 489 (Crush sleeve preload). There were two SureGrips; Dana Power Lok ('62-'69) (clutch type) and Borg-Warner Spin Resistant ('69-'74) (cone type). The cone type is not easily rebuildable, the clutch type is.
The strongest of these (489) as stock will cope with quite a lot of HP behind an automatic. For this reason a lot of people find and fit this type and swap out the other types.
However the "weaker" types are still VERY strong. These axles are one of Mopars strong points. So if you can find one use it.
Hope that helps.
