here are my motor specs
69 340
balanced rotating assembly
bored .030 over
speed pro pistons (I want to say 9.5:1 compression but im not exactly sure)
Eagle forged rods
comp exhaust valves and valve springs
3 angle valve job
edelbrock performer duel plane manifold
holly 670cfm street avenger carb
hooker super comp long tube headers
MSD 6al
Freddy Brown built 727 tranny with manual valve body/shift kit
Here are the comp cam specs: intake lift: .480/ Exhaust: .480
230/230 duration at .050
Grind: CRS 280h-10
My boss at the speed shop I work for, who is also the guy who built the motor thinks 4.88's would be good for my application. When we can finally get it to the track in jersey, 4.88's and a higher stall (right now it only has a 2300) might be enough to get it into the low 12's (?) which I would be very happy with. My only problem is that I plan to run nitrous in the future and I don't want to run out of gear on the spray. On the other hand, I also want the car to run as best as it could N/A, as that is how i'd be driving it 90% of the time. Im using M/T L60 I tread sportsmans right now. I think they are about 28" in diamter. I guess I would go with a similar sized slick.
thanks!
