Dave,
Following on from the great 'Shifter debate', my attention turns to rear gears. I was sold on a set of 3.91's, but having used your Spreadsheet to check RPM, it seems I'm seriously going to run out of steam with my tyres. 3.55's appear to be a much better proposition.
Just to double- double check, am I safe to assume the 1.08 trans ratio in your calculation is the "D"/ 3rd gear in a 727?
Also, I took a tape measure to my rear tyres last night, and got a diameter of 26.5 inches (this is for 275/60/15's, with good tread). Is your tyre diameter calculation pretty foolproof? It could just be I need 20lbs of air adding to the tyre I was measuring.
I'll stop asking annoying questions (fairly) soon.
Many Thanks
Tim.
