after 2 years, I finally finished my restauration, but after a nice test-drive to the MOT-test(i've passed!), i found out that my rear diff. bearings are worn-out(found a lot of metal when i changed the diff oil), i also discovered that i need some sort of Limited Slip diff... , i was thinking to buy a complete third member, any recommedations?
as for the axle ration, i don't know what ratio i've got know, should i change to a high or low ratio for better acceleration?
Do most challengers have a 8 3/4 axle?or a dana 60? should i chose a 489 or a 742 case?
my tire size is 275/65/15
thank you!
david
