 by Follicly Challenged » 15 Feb 2005 14:21
			Yep, bin there, done that.
Get ahold of strange, bear performance(canada), or one of numerous suppliers and request dana 60 axle tube ends to match whatever backing plates and brake setup you're gonna use.
Best have the actual cut and narrowing performed by a pro WHO HAS A JIG, to prevent heat warping when welding, otherwise you may experience some trouble inserting the axles afterwards.
JIG; Long piece of straight cold roll that fits through the housing from end to end. "dummy" bearing plugs that fit the actual brg receiver in the ends, and machined to slip over the cold roll. Any of numerous retention methods you can dream up. This "holds the three pieces together and aligned for welding. The 3 pcs being: the cut housing, and replacement 2 ends.
Best if this whole setup stands on a nice firm bench for welding, many shops actually have a roll over fixture for doing this on a regular basis as we used to.
You'll need to order axles as well, also a good idea to let a pro do this as if wrong when delivered, you own 'em, period ! Lots of considerations when ordering axles with regards to backing plate spacing, bearing position, etc., etc.
If you're gonna do it yourself, get the supplier to fax you a build sheet with diagram, fill it out with a good sketch of dimensions ,etc. Fax what you want and KEEP THE ORIGINAL, have them return the fax with the axles, thereby insuring you get what you ordered.
Overall, not impossible, but best left to a pro as Dave said in 2 sentences, LOL
Bob out
