OK.
The measurement for bearing preload is 20-35 inch/lbs for new bearings and 10-15 inch/lbs for used. This is without the axles in place of course.
It does vary from pinion type to pinion type but these figures will get you in the ballpark.
Just make sure you have reached the minimum 240 or 170 lbs/ft on the pinion nut to get this pre-load depending on the type you have.
Maybe it is time you bought a workshop manual?
