When I drive at around 55 mph there is a resonating vibration. If I increase the gas the resonating time increases and if I lifht up the pedal the resonation time is around 3 seconds. Drive shaft not balanced properly or is there a possibility that the turbine (10 inch) is not balanced??
340 CID, 727 gearbox, 8 3/4 with 3.91 ratio.
