 by Christer » 30 Jun 2004 10:34
			The pressure in the whole automatic is controlled through the kick-down rod/rods. If the kick-down rod is missing, the valve housing inside the automatic gets a signal to keep a low preassure even if you give full throttle. That is, the cluches will become worn quite quick. This is the way I have understood it.
