 by moparmaniac (owner4) » 16 Apr 2004 4:38
			If the ratio tag is missing from one of the carrier nuts, then you need two people one to count the rototion of the drive shaft and one to watch the rotation of the tire. Jack the rear end up so tires are not touching the ground and secure the housing with jack stands. Make a mark on the tire (Pass side) and one on the floor. put the car in nuetral and if I remember right, with one 360 degree rotation of the drive shaft, you count how many times the the marks meet on the tire/ floor. If the tire doesn't make a full revolution, you can break it down in quarters. such as 2.76 is about 2 and 3/4 revolutions of the tire and 3.23 is about 3 and 1/4 revolutions and so on.
