A: Maximum performance can only be obtained when the entire combination of engine components are matched to work together.
B: Determine the converter stall spped requirements based on the powerband of your camshaft.
C: Order your converter only when you know all the specific factors that will affect the stall speed design.
D: As a general rule for street use obtain a stall speed with a minimum of 500 rpm into your powerband. This will allow your engine to get into the area where it is designed to operate and your engine will make enough power to drive the converter to its' stall range.
Some examples.
Cam Duration 260
Powerband rpm 1200 - 4200 rpm
Cruise rpm @ 100KM/H 2000-2500
Recommended stall 2000-2500 rpm
Cam Duration 272
Powerband rpm 2000 - 5000 rpm
Cruise rpm @ 100KM/H 2500 -3000
Recommended stall 2500 - 3000 rpm
There are other examples, and if anybody wants them please let me know. These are just general examples of course, but should give the board members some general guidelines to start with.
I picked this information up a recent performance seminar and thought I should pass it along.
Graham
 by transman » 11 Mar 2004 6:34
